Tagged values
In BP-VA, tagged values are properties defined by user and can be added to a model element. BP-VA supports either defined tagged values in stereotype or tagged values without stereotype.
Adding user-defined tags
  1. Right click on the selected shape and select Open Specification... from the pop-up menu.
    Open specification
    Open specification
  2. In Specification dialog box, select Tagged Values tab and click Add button to select an option of value type.
    Add an option of value type
Different types of tagged values
Text
Text supports string-based value.
In Specification dialog box, select Tagged Values tab, click Add button and select Text from the pop-up menu. Enter the text in the text field directly.
Add text
Add text
Multi-line Text
Multi-line Text supports multi-line string.
  1. In Specification dialog box, select Tagged Values tab, click Add button and select Multi-line Text from the pop-up menu. Click the ... button of Value.
    Add multi-line text
    Add multi-line text
  2. When Edit Value dialog box pops out, enter the multi-line text. Click OK button to finish editing.
    The Edit Value dialog box
Model Element
Model Element supports reference(s) of model element.
  1. In Specification dialog box, select Tagged Values tab, click Add button and select Model Element from the pop-up menu. Click the reverse triangle button of Value.
    Add model element
    Add model element
  2. When the Select Model dialog box pops out, check Model and select a model element. Click OK button to confirm.
    Select a model element
Integer
Integer supports values with numbers only.
In Specification dialog box, select Tagged Values tab, click Add button and select Integer from the pop-up menu. Enter a number in Value.
Add integer
Add integer
Floating Point Number
Floating Point Number supports values with decimal places.
In Specification dialog box, select Tagged Values tab, click Add button and Floating Point Number from the pop-up menu. Enter a number with decimal places in Value.
Add floating point number
HTML
HTML is a hidden tagged value. To reveal this option, select Tools > Options... from the main menu. When the Options dialog box pops out, select Diagramming > Environment tab and check Stereotype support HTML tagged value.
In Specification dialog box, select Tagged Values tab, click Add button > HTML Text from the pop-up menu and click ... button in Value when the option for HTML is revealed.
Add HTML text
Add HTML text
When Edit Value dialog box pops out, enter the text. You can format the HTML text content with the toolbar, for example, changing the font color of selected text and underlining selected text.
Format the HTML text content
Editing tagged values
You can enter the user-defined tagged value's name, select its type and enter its value.
Edit name, type and value on user-defined tagged value
The value of stereotype can be edited, however, its name and type cannot be edited as they are defined in stereotype.
Visualizing tagged values on diagram
Right click on the diagram background and select Presentation Options > Show Tagged Values from the pop-up menu.
Show tagged values
Show tagged values
If it is defined, the tagged values will be seen within the shape(s) on the diagram.
Tagged values are shown
2. Resource-centric interface Table of Contents 4. Spell checking
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
