Technical Support
Sales Support
You will never find it hard to avoid making mistakes in your diagram after using spell checking. It can help you to correct both typing mistakes and spelling mistakes, however, it is slightly different from other spelling and grammar checking tools you have used before. It doesn't check your whole diagram automatically, but underlines wrong words with a curve line.
If you type an incorrect word mistakenly, you can:
Sometimes, the dictionary cannot recognize the word you type and it doesn't always mean you type an incorrect word. It may be a rare word or a new word that you create, you can simply right click on the wrong word and select Add to dictionary to add a new word to dictionary. You type this word again next time, it won't be marked as a wrong word.
| Add a new word to dictionary |
The dictionary usually defaults as American English for spell checking. If you want to change the language of dictionary, you just need to:
| Change the language of dictionary |
| NOTE: | There are a few more languages in dictionary that can be used, such as French and German. |
There are a few more options of spell checking, including Check spelling as you type, Ignore words in UPPERCASE, Ignore words with numbers and Ignore Internet and file address. Check the item you want to be included in spell checking. Otherwise, uncheck the item you don't want to be included.
| Check other options of spell checking |
| 3. Tagged values | Table of Contents | Chapter 2. Project management properties |
Technical Support
Sales Support
