RTF documentation
With rich text format (RTF), you can format the text in documentation editor, such as making it bold, italic, or adding tables within the text.  In addition to formatting, RTF supports users to add linkage to another model element, save documentation as template and furthermore reuse the template.
Viewing and editing the documentation of model element
To view or edit the documentation of model element, right click on the shape and select Open Specification... from the pop-up menu.
Open specification
Open specification
Alternatively, click the Documentation pane after select a specific shape on the diagram pane.
Documentation pane
Documentation pane
Documentation editor
The documentation pane is where you can describe the selected model element. With the editor's toolbar, you can format the content, save as template, reuse the existing template, add model elements and print the content.
The overview of documentation editor
The toolbar on documentation editor
No. Name Description
1
 HTML
HTML - Read and edit the real content.
HTML Source - Read and edit the HTML source of content.
Plain Text - Read and edit plain text of content without formatting.
2
Bold
Set the highlighted text to bold.
3
Italic
Set the highlighted text to italic.
4
Underline
Underline the highlighted text.
5
Alignments
Set the alignment of highlighted text to the left, the center or the right.
6 Ordered list Add a numbered list.
7 Un-ordered list Add a list with bullet points.
8 Font Select the font family of highlighted text.
9 Font size Select the size of highlighted text.
10 Font color Select the color of highlighted text.
11
Table Add a table.
12
Background color
Select the background color of highlighted text.
13 Clear formats Clear formats of the whole editor to convert the content to plain text.
14 Link Add a hyperlink.
15 Image Add an image.
16 Add Model Element Insert an existing model element or create a new one.
17 Template
Save as Template...: Save the current documentation content as a template.
Manage Template...: Delete the saved template.
18 Print Print the documentation content.
19 Editor pane Enter and start editing the documentation content.
The description of documentation editor
Editing documentation
Saving a template
  1. The documentation you typed can be saved as template in the documentation editor. Choose Save as template... from the drop-down menu of Template.
  2.  In the Input dialog box, enter the template name and click OK button to confirm.
    Enter template name
    Enter template name
Reusing a template
  1. In the documentation editor, an existing template can be reused. Select a saved template from the drop-down menu of Template.
    Select a template
    Select a template
  2. As a result, the selected template will be shown on the documentation editor.
Adding model element
  1. Click Add Model Element button on the editor's toolbar after decided a place for inserting a model element.
  2. In Select Model dialog box, select an existing model element on the list. If you want to modify the selected model element, you can click Open Specification... button. On the other hand, you can create a new model element by clicking New... button after select a model element on the list.
    Select a model element
  3. Finally, click OK button to confirm.
  4. Consequently, the name of inserted model element will be shown on the documentation pane with underline. If you want to preview the inserted model element, you can right click on its name and select Show View... from the pop-up menu. After the Show View dialog box pops out, you can preview it in the Preview window. If you want to view the actual model element on the diagram, you can click Go to View button.
    Click Show View... from the pop-up menu
Printing documentation
  1. After clicking the Print button, the Page Setup dialog box will pop out.
    Click Print button
    Click Print button
  2. In Page Setup dialog box, select size and source for paper, check an option under Orientation and enter the inches for the paper margins.
    The Page Setup dialog box
  3. Click OK button to confirm printing.
Chapter 3. Documenting model elements Table of Contents 2. Voice documentation
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
