Technical Support
Sales Support
Alignment is the adjustment of an object in relation with other objects. Therefore, the diagram alignment means adjusting a shape's position with another's (or others') in a straight line or in parallel lines. When you drag shapes, alignment guide will appear to let you position the dragging content in accordance with existing shape(s).
When you drag a shape upward or downward, two horizontal lines will reveal on the both edge of the shape as an offer of assistance for adjusting the shape's position.
| Drag upward |
Similarly, when you drag a shape to the left or the right, two vertical lines will reveal on the both edge of the shape.
| Drag to the right |
When you drag a shape upward or downward, a horizontal line will reveal in the center of the shape as an offer of assistance for adjusting the shape's position.
| Drag upward |
Similarly, when you drag a shape to the left or the right, a vertical line will reveal in the center of the shape.
| Drag to the right |
If you want the alignment guide to help you position when you drag shapes, check Show diagram alignment guide; on the contrary, uncheck it if you don't need a help. Two Choices are provided in alignment guide: Show edges and Show center. Choose Show edges if you want two horizontal lines to reveal on the both edge of the moving shape while choose Show center if you want a horizontal line to reveal in the center of the shape.
| Change alignment guide options |
| 4. Copy and Paste | Table of Contents | 6. Reverse Connector Direction |
Technical Support
Sales Support
