Technical Support
Sales Support
The flow between shapes is represented by connectors, for example, a sequence flow between task 1 and task 2 which represents the sequence of task from task 1 to task 2. If the flow is created mistakenly, or the flows need reverting due to an updated data, the flows can be fixed by reverting connectors.
| Select Reverse Connector from the pop-up menu |
| Connector is reversed |
| NOTE: | This feature is only available for sequence flow of business process diagram. |
| 5. Alignment Guide | Table of Contents | 7. Visualize Model Elements on Diagram |
Technical Support
Sales Support
