Callout shape
Callout shape is a label that is used for explicating your model elements. Inserting callout shape aims to draw others' attention and give them additional remarks. Basically, its function is similar to a photo caption or a comment. However, it does more than merely either a photo caption or a comment. In fact, it looks more likely to a dialog box that you can place it next to your model elements.
Adjusting the direction of callout shape pointer
  1. A remark can be inserted by selecting Callout button from the diagram toolbar and dragging it to the model elements directly on the diagram pane.
  2. The direction of callout shape pointer can be adjusted by simply dragging the pointer's end.
    Adjust the pointer
    Adjust the pointer
  3. The pointer can be adjusted to point out a more specific position, such as pointing to the name of diagram element, or a specific class member (attribute/operation) out of a class.
    Adjust the pointer to a specific column
    NOTE: You can not only adjust the pointer's direction, but also its length.
Repositioning the shape
The position of callout shape can be moved by dragging the + icon that is located on the top right corner of the callout. This icon is used to reposition the shape in a straight and simple way.
Reposition the callout
NOTE: The callout shape will be moved but the position of its pointer won't be changed if you only drag the + icon. This helps you to remain the pointing and move the callout shape simultaneously.
Editing callout shape content
The content of callout shape can be edited by double clicking on the callout shape.
Emphasizing the content of callout shape
Formatting buttons can be used to insert formatting for the text in order emphasize your key points while you are editing the content, such as changing font color. This helps to enhance the visual effect of the text as well.
Format the text
Format the text
1. Text annotation Table of Contents 3. Freehand Shape
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
