Technical Support
Sales Support
<StaticText> is a construct which enables you to insert your own text into a report, at the position where <StatcText> is processed. You can add your text with custom formats.
| Supported attributes for <StaticText> |
<StringPropertyText> is the most commonly used construct in a report template document. It is used to extract a string property from model element (e.g. name of a class) and print it to report.
| Supported attributes for <StringPropertyText> |
<IntPropertyText> is a construct which enables you to extract an integer property from model element (e.g. length of an entity column) and print it to report.
| Supported attributes for <IntPropertyText> |
<BooleanPropertyText> is a construct which enables you to extract a boolean property (i.e. true/false) from model element (e.g. abstract of a class) and print it to report.
| Supported attributes for <BooleanPropertyText> |
<ParagraphBreak> is a construct which enables you to add a break in report to separate text into paragraphs. <ParagraphBreak> does not carry any text.
<PageBreak> is a construct which enables you to insert a new page at where <PageBreak> is processed.
| 6. Reading model - Model/diagram element | Table of Contents | 8. Table |
Technical Support
Sales Support
