Technical Support
Sales Support
A diagram loop is a component in a report template, indicating the need of looping (i.e. walking through) specific type(s) of diagram. For example, to loop all business process diagrams and class diagrams in a project. Diagram loop means nothing more than just to loop diagram. The content to print for each diagram being looped is to be determined by the children components of loop.
To loop specific type(s) of diagrams in project, create diagram loop at template root. To create diagram loop at template root:
| Select to loop use case diagram |
Stereotypes and glossary grid fall into the category of diagram. If you want to print them to report, follow the steps as described in the previous section, and to select the appropriate content to include at the final step.
| Choosing to include glossary grid in template |
Instead of looping diagrams in a project, you can also place diagram loop under an element loop to loop for sub-diagrams of specific type(s) of model element. To create diagram loop under an element loop:
| Selecting an element loop |
| Adding a diagram loop |
| NOTE: | Make sure you are clicking on the button from the toolbar of element loop. If you are clicking on the button at editor toolbar, you will create a loop at template root. |
A diagram summary indicates the need of looping specific type(s) of diagram for constructing a tabular diagram summary, while a diagram paragraph indicates the need of looping specific type(s) of diagram for constructing paragraphs of properties.
You can convert a diagram loop to diagram summary table or paragraph by right clicking on a diagram loop and selecting Change to Summary Table/Paragraph from popup menu.
| To convert a diagram loop to diagram summary table/paragraph |
| 2. Export/import report template | Table of Contents | 4. Diagram summary |
Technical Support
Sales Support
