Technical Support
Sales Support
An element loop is a component in a report template, indicating the need of looping (i.e. walking through) specific type(s) of diagram/model elements. For example, to loop all task and sub-process in a project. Element loop means nothing more than just to loop diagram/model element. The content to print for each diagram/model element being looped is to be determined by the children components of loop.
To loop specific type(s) of model elements in project, create element loop at template root. To create element loop at template root:
| Description of available type of element loop |
| Select to loop pool |
| NOTE: | You can switch between a root level and a all-level loop by changing the option Root Level above the element list. Notice that changing the value of Root Level is not about changing available element selection, but also the end result, whether to access only root level elements or not. |
Instead of looping model elements in a project, you can also place element loop under a diagram loop to loop for diagram elements in specific type(s) of diagram. To create element loop under a diagram loop:
| Selecting a diagram loop |
| Adding an element loop |
| NOTE: | Make sure you are clicking on the button from the toolbar of diagram loop. If you are clicking on the button at editor toolbar, you will create a loop at template root. |
An element summary indicates the need of looping (i.e. walking through) specific type(s) of diagram/model element, and presenting their properties in tabular form, while an element paragraph indicates the need of looping specific type(s) of diagram/model element for constructing paragraphs of properties.
You can convert an element loop to element summary table or paragraph by right clicking on a element loop and selecting Change to Summary Table/Paragraph from popup menu.
| To convert an element loop to element summary table/paragraph |
| 5. Diagram paragraph | Table of Contents | 7. Element summary |
Technical Support
Sales Support
