Completion
Sometimes, just by watching the simulacian outcome is not enough in finding out the bottleneck, especially when the diagram is large, and has many, many bottlenecks. In such cases, you can produce charts for simulacian outcome, which helps quantify resource consumption and queuing time for each flow object.
To read the charts, click Simulacian Charts in simulacian control panel.
Open simulacian charts window
Completion chart
The completion chart primarily shows the status of inputs completion against time.
An overview of completion chart
No. Name Description
1 Resource usage
Click to show resource usage chart.
2 Queue time
Click to show queue time chart.
3 Cost Per Flow Object Click to show cost per flow object chart.
4 Cost Per Input Click to show cost per input chart.
5 Time Cost Click to show time cost chart.
6 Time scale
Control the length of chart by selecting a time scale.
7 Auto refresh
Check to let the chart body auto update against chart settings such as time scale and selection of inputs. Uncheck to update manually by clicking Refresh.
8 Refresh
Click to update the chart body against the chart settings such as time scale and selection of inputs. This button is available only when Auto Refresh is unchecked.
9 Not yet started inputs
Check or uncheck the inputs to show or hide in chart the change of the amount of not-yet-started inputs throughout simulation.
10 Processing inputs
Check or uncheck the inputs to show or hide in chart the change of the amount of processing inputs throughout simulation.
11 Completed inputs
Check or uncheck the inputs to show or hide in chart the change of the amount of completed inputs throughout simulation.
12 Chart body
The chart body.
13 Export
Click to export the opening chart to Microsoft Excel or image file.
14 OK
Click to close the simulacian charts window and go back to the diagram.
Description of completion chart
Chapter 2. Simulacian charts Table of Contents 2. Resource usage
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
