Technical Support
Sales Support
Sometimes, just by watching the simulacian outcome is not enough in finding out the bottleneck, especially when the diagram is large, and has many, many bottlenecks. In such cases, you can produce charts for simulacian outcome, which helps quantify resource consumption and queuing time for each flow object.
To read the charts, click Simulacian Charts in simulacian control panel.
| Open simulacian charts window |
The resource usage chart shows the percentage of resource consumption throughout simulation. If a resource has its peak reaching 100%, it means that the allocation of that resource is in optimum state. If the peak is below 100%, it means that some of the resources are not used throughout the simulation, which usually signifies that they are wasted, and you should consider adjusting the amount of available resource to optimize the resource consumption.
| An overview of resource usage chart |
| Description of resource usage chart |
| 1. Completion | Table of Contents | 3. Queue time |
Technical Support
Sales Support
