Queue time
Sometimes, just by watching the simulacian outcome is not enough in finding out the bottleneck, especially when the diagram is large, and has many, many bottlenecks. In such cases, you can produce charts for simulacian outcome, which helps quantify resource consumption and queuing time for each flow object.
To read the charts, click Simulacian Charts in simulacian control panel.
Open simulacian charts window
Queue time chart
The queue time chart shows the time the flow objects spent on waiting, which corresponds to the time an inverted triangle appear during simulacian. You may study whether the queue time of certain flow object is reasonable or not, and think of the improvement.
An overview of queue time chart
No. Name Description
1
Completion
Click to show completion chart.
2
Resource usage
Click to show resource usage chart.
3 Cost Per Flow Object Click to show cost per flow object chart.
4 Cost Per Input Click to show cost per input chart.
5 Time Cost Click to show time cost chart.
6
Time scale
Control the length of chart by selecting a time scale.
7 Auto refresh Check to let the chart body auto update against chart settings such as time scale and selection of nodes. Uncheck to update manually by clicking Refresh.
8 Refresh Click to update the chart body against the chart settings such as time scale and selection of nodes. This button is available only when Auto Refresh is unchecked.
9 Nodes Check or uncheck flow objects nodes to show or hide their queue time in chart.
10 Chart body The chart body.
11 Export Click to export the opening chart to Microsoft Excel or image file.
12 OK Click to close the simulacian charts window and go back to the diagram.
Description of queue time chart
2. Resource usage Table of Contents 4. Cost per flow object
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
