Filter and find
BP-VA enables you to create a grid to list whatever model element type you like, and customize the properties of model element being shown inside the grid. Except creating a grid with your preferred model element type, you can also search your target model element in shortcut through filter and find.
Filtering
  1. Type the word/ phrase in filter.
  2. Model element(s) matching the word/ phrase you typed will be shown in the grid subsequently.
    Model elements match the word/ phrase you typed
Finding
  1. Click Find button.
    Click Find button
    Click Find button
  2. Type the word/ phrase in Search Text and then check either Name or Documentation (or both). Check Name if you want to search the name model elements matches the word/ phrase you typed while check Documentation if you want to search the documentation of model elements matches the word/ phrase you typed. Check both if you want to search the name or the documentation of model elements matches the word/ phrase you typed.
    Check Name
    Check Name
  3. Click Find button behind Search Text.
    Click Find button
    Click Find button
  4. Model element(s) matching the word/ phrase you typed will be highlighted in the grid subsequently.
    Model elements are highlighted
4. Setting the scope of grid content Table of Contents Part X. Business process execution
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
