Technical Support
Sales Support
To represent the initiation of a BPEL process, you need a start event, which correspond to, in BPEL a receive element with attribute createInstance set to yes. You can specify the partnerLink, portType and operation to be invoked by the start event.
| NOTE: | An alternative way to start a process is to start by a receive task. Create a receive task, open its specification and check Instantiate in its General tab. |
To edit BPEL properties for a start event, right click on the start event and select Open BPEL Specification... from the popup menu. In the specification dialog box you can specify partner link, operation and variable.
| Open BPEL specification |
| 3. Pool (process) | Table of Contents | 5. Task |
Technical Support
Sales Support
