From BPD to jPDL
jPDL, short for jBPM Process Definition Language, is a language defined by JBoss for specifying an XML and the mechanism to package all the process definition related files into a process archive.
BP-VA supports modeling business process in BPD and generating jPDL from it.
Process
A process stands for a business process. In a BPD, process is modeled by a pool. In a process, there are tasks and transitions. Normally, no process details need be specified for jPDL.
A pool
A pool
Participant
A participant stands for a user of the business process. In a BPD, participant is modeled by lane in pool. Same as process, no participant details need be specified for jPDL besides the participant name.
A lane
A lane
Task
A task stands for something needed to be handled. In a BPD, task is directly modeled by a task. If the task is a User Task or Manual Task, the task need be started and completed by user. Otherwise, it will be completed automatically.
A task
A task
To set the type of task, right click on the task and select Type, and the type from the popup menu.
Setting a task's type
Supported element types
The following model element types are supported by jPDL generation. The rest will be ignored.
Element Supported Model Element Type
Task-node
  • Manual task
  • User task
Node
  • Typeless task (i.e. task without type specified)
  • Business rule task
  • Receive task
  • Reference task
  • Script task
  • Send task
  • Service task
Decision
  • Typeless gateway (i.e. gateway without type specified)
  • Complex gateway
  • Data-Based Exclusive gateway (XOR)
  • Event-Based Exclusive gateway (XOR)
  • Inclusive gateway (OR)
Fork
  • Parallel gateway (AND)
Super-state
  • BP Group
End-state
  • Typeless end event (i.e. end event without result specified)
  • Cancel end event
  • Compensation end event
  • Error end event
  • Escalation end event
  • Link end event
  • Message end event
  • Multiple end event
  • Signal end event
  • Terminate end event
Start-state
  • Typeless start event (i.e. start event without trigger specified)
  • Compensation start event
  • Error start event
  • Escalation start event
  • Link start event
  • Message start event
  • Multiple start event
  • Parallel start event
  • Rule start event
  • Signal start event
  • Timer start event
Supported model element types
Generating JPDL
For jPDL, all components in a process, including flow objects and flows, must be named, and named uniquely. Note that if an element has no name given, a default name Unnamed{N} will be assigned to that element. If the name is duplicated. The {N} will be appended to that element, where the {N} is a sequence number.
  1. Right click on the background of BPD and select Diagram Type > jPDL from the popup menu.
  2. Right click on the background of BPD and select Utilities > Generate jPDL from the popup menu.
    To generate jPDl
    To generate jPDL
    NOTE: If you have received an error, make sure your process was correctly modeled. For example, did you draw a non supported shape type like sub-process? If yes, revise the design by removing those non supported shape and possibly replace with others.
  3. Enter the folder and click OK. The output files are generated. They includes:
    • BookStore.zip (Deployable process archive)
    • gpd.xml (Graphical process definition)
    • processdefinition.xml (Process definition)
    • processimage.jpg (Process image)
Chapter 2. jPDL Table of Contents Chapter 3. XPDL
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
