Technical Support
Sales Support
It would be much more efficient to make use of Model Explorer for your middle to large scale project which has considerable numbers of diagrams and model elements, rather than through Diagram Navigator.
| The Model Explorer |
| The description of icons on Model Explorer |
The Model Explorer lists all the model elements in the project.
| The popup menu of Model Explorer |
| Menu Title | Description |
| Model |
Create a Model. |
| Model Element... |
Create a new Model Element or select a default model in Model Explorer. |
| Filter Model Element... |
Open the Model Element Filter dialog box to filter the diagram elements to appear in the Diagram Navigator. |
| Show Relationships |
Show also Relationship model elements in Model Explorer (default hidden). |
| Show Sub Diagrams |
Show Sub Diagrams in Model Explorer so that user can browse and open Sub Diagrams in Model Explorer. |
| Show Data Types |
Show Data Types in Model Explorer (default hidden). |
| Show Carriage Return Character |
Display line breaks of multi-lined diagram name as carriage return character. |
| Sorting |
Select the way to sort model elements in Model Explorer. |
| Teamwork |
Perform teamwork activities. |
| Manage Dependent Project... |
Add or remove dependent project. |
| Refresh | Refresh Model Explorer content. |
| Collapse All | Collapse all tree nodes. |
| Expand All | Expand all tree nodes. |
| The popup menu of project node in Model Explorer |
| No View Model Elements... | It lists the model element(s) that either has not been visualized (no view) or has no master view. |
| Rename... |
Rename the project. |
| Nicknames |
Configure or switch to another nickname. |
| Create Profile | Create a profile. |
| Model |
Create a Model. |
| Model Element |
Create a new Model Element in Model Explorer without the need of creating through diagramming. |
| Configure Programming Language... |
Change to another programming language or configure the type mapping for a language. |
| Sorting |
| Show Sub Diagrams |
| Show Data Types |
| Teamwork |
| Manage Dependent Project... | Add or remove dependent project. |
| Refresh | Refresh Model Explorer. |
| Collapse All | Collapse the project node. |
| Expand All | Expand the project node. |
Model Explorer is opened by default. To close it, press the X button at the top right corner. On the other hand, it can be opened by selecting View > Panes > Model Explorer from the main menu.
A model is a package like UML element that can store model elements and diagrams. Users are recommended to structure project by using model in order to maintain a clear structure for accessing project data and improve the application performance.
Right click on the root node in Model Explorer and select Model from the popup menu. You can either create a custom model by selecting New Model..., or create a pre-defined model by selecting it in the list.
| Select New Model in pop-up menu |
A model element is created when you create a shape on a diagram. If you want to create a model element without visualizing it, you can create it through the Model Explorer. To create a model element:
| Select New Model Element from the pop-up menu |
| Open Form Diagram dialog box |
In model explorer, model elements are listed under root nodes. You can sort model elements by their names, by their types (e.g. use case, package, etc.) or with no sorting.
To sort by name, click Sort by Name button. The elements will be listed by name, in alphabetical order.
| Sort model elements by name |
To sort by type, click Sort by Type button. As a result, the elements will be listed by type. To arrange model elements without sorting, click No sorting.
Select the model element(s) you want to reorder. If there are multiple model elements you want to select, just click one while pressing Ctrl button and make the other selections.
Click Move Selected Model Element Up button to move the selection upwards, or Move Selected Model Element Down button to move the selection downwards.
| NOTE: | This option only works within the same model element type when there are multiple model elements. |
You can choose which model elements you want to be displayed or not on the model explorer.
Right click on the model explorer's background and select Filter Model Element. In Model Element Filtering Dialog, select the types of model element(s) you want to be displayed by checking the type. Otherwise, uncheck the one you don't want to be displayed.
| Model Element Filtering Dialog |
| NOTE: | Instead of displaying all types of model elements, checking Display model element types in-use to display the types of model elements used in the project. |
If it is the case that the name of model elements is in multi-line, the character ¶ will be revealed.
When Show Carriage Return Character is selected, line break will be shown.
| Show Carriage Return Character is selected |
When off, the character ¶ is hidden.
If you want to hide it, uncheck Show Carriage Return Character and the character will automatically be unshown.
VP-UML's team collaboration support enables your team members work together on projects. To connect to server and perform related activities:
| Perform teamwork |
| 4. Diagram navigator | Table of Contents | 6. Class repository |
Technical Support
Sales Support
