Technical Support
Sales Support
Documentation pane enables you to document project data such as model elements, shapes or diagrams either in written or verbal form. For written content, it can be a plain text or HTML text with formattings like bold, italic, table, etc.
| The Documentation pane |
| The description of icons on Documentation pane |
Documentation pane is opened by default. To close it, press the X button at the top right corner. On the other hand, it can be opened by selecting View > Panes > Documentation from the main menu.
Documentation pane enables users to type in the textual description for project data, for instance, model elements, shapes and diagrams.
A word or a lexis can be defined as a glossary item for explication.
| Select Add "premium" to Glossary from the pop-up menu |
| Click Open Term Editor from the pop-up menu |
| Type an alias for the new item |
| Enter term definition |
When you type an incorrect word carelessly, documentation pane can offer you a help.
For correction, right click on the incorrect word with a red curved line and select one out of the suggested words from the pop-up menu.
| Select a correct word from the pop-up menu |
Moreover, you can add a new word to the dictionary if the word you typed is a rare word or a new created word. Right click the new word and select Add to dictionary from the pop-up menu. When you type the word next time, it won't be marked as an incorrect word again.
In addition to textual description, documentation pane also enables users to document for project data in verbal form.
Click Record... button for recording voice.
| Click Record... button |
In Record Voice dialog box, enter the name for the audio clip. Click Record to start recording while click Stop to terminate. Click OK if you want to save the voice recording; click Cancel, and vice verse.
| Click Record in Record Voice dialog box |
| The description of icons on Record Voice dialog box |
| 10. Diagram overview | Table of Contents | 12. Stencil pane |
Technical Support
Sales Support
