Technical Support
Sales Support
You can customize the settings of each diagram you created in diagram specification dialog box. Those settings include: general diagram information, grid setting, references, project management and comments. Diagram specification dialog box is similar with model element specification dialog box in which you can also enter general information, add/ remove references, enter project management and add/ remove comments.
| Open a diagram's specification dialog box |
| Diagram specification |
A diagram specification dialog box is consist of 5 tabs: General, Grid Setting, References, Project Management and Comments respectively. You may notice that an icon named Maximum located at the right hand side of dialog box. We'll introduce it after giving you a brief on 5 tabs.
You can specify diagram name, select zoom ratio and diagram background color, and enter documentation for the diagram. Furthermore, you can record voice documentation for the diagram. You can set all shapes including existing and future shapes to be fit size automatically.
You can visualize the grid of diagram background by checking Grid visible. Moreover, you can set the size and select the color for the grid of diagram background.
You can add/ remove internal and external references for the diagram. Those references refer to file(s), folder(s), URL, diagram(s), shape(s), model element(s) and A³ resource(s).
You can specify diagram process, priority, status, etc for project details.
You can add/ remove comment(s) for the diagram.
Click
to enlarge the specification dialog box to the maximum screen size. Click it again to reduce it to the default size.
| 12. Stencil pane | Table of Contents | 14. Perspective |
Technical Support
Sales Support
