Model's specification dialog
In VP-UML, you can open a model's specification dialog box to view and edit the model's details. The options, such as references, project management and comments are categorized into tabs in the specification dialog box. Furthermore, three buttons attached on the right-hand side of dialog box are Pin, Auto open specification when select and Maximum. Model specification dialog box is similar with diagram specification dialog box in which you can also enter general information, add/ remove references, enter project management and add/ remove comments.
Opening a model's specification dialog box
Right click on the target model which you want to view or edit its details and select Open Specification... from the pop-up menu.
Open specification dialog box
As a result, the model's specification dialog box pops out.
The Entity Specification dialog box
The overview of three buttons on model's specification dialog box
Pin
To pin the specification dialog box, press Pin button.
Press Pin button
Press Pin button
NOTE: This button works in combination with Auto open specification when select.
After you've pinned the specification dialog box, press this button. After all, you don't have to close the current dialog box in order to open another model's specification box.
  1. Press Auto open specification when select button.
  2. Select another model to view its specification dialog box by clicking on the target model.
    Click data store
    Click data store
Maximum
Press this button to enlarge the specification dialog box to the maximum screen size.
Click Maximum button
After that, click it again to reduce it to the default size.
14. Perspective Table of Contents Chapter 5. Working with projects
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
