Technical Support
Sales Support
A toolbar can be shown or hidden. To show a toolbar, right-click on any toolbar, and select the toolbar to show. Similarly, you can uncheck a toolbar to hide it.
| Show or hide Standard toolbar |
A toolbar can be repositioned by pressing on the handle of toolbar, which appears on the left hand side of a toolbar, and dragging to your target position.
| Drag toolbar with the handle of toolbar |
To freeze toolbars' position and make the toolbars not movable, right click on any toolbar and uncheck Rearrangable from the pop-up menu.
| Uncheck the Rearrangable option |
| The Standard toolbar |
| Icon | Name | Description |
| New Project |
Create a project. | |
| Open Project |
Open a project. | |
| Save Project |
Save the changes made in the opening project. | |
| Print... |
Select and print diagram(s) after configure the advanced printing set up. | |
| Print Active Diagram... | Select and print diagram(s) after configure the advanced printing set up. | |
| Quick Print... | Print the active diagram after configure the advanced printing set up. | |
| Cut |
Cut selected diagram elements. | |
| Copy within VP-UML |
Copy selected diagram elements ready to be used within VP-UML. | |
| Copy to Clipboard as Image (JPG) |
Copy selected diagram elements as JPG image. | |
| Copy to Clipboard as Image (EMF) | Copy selected diagram elements as EMF image. | |
| Copy to Clipboard as XML |
Copy selected diagram elements as XML data. | |
| Paste View |
Paste copied diagram elements as view of original model element. | |
| Paste Model Element | Paste copied diagram elements as a new model element. | |
| Undo |
Roll back undesired changes. | |
| Redo | Rerun an undone task. | |
| UML Modeling | Select and create a diagram type under UML Modeling, including: Use Case Diagram, Use Case Grid, Actor Grid, Class Diagram, Composite Structure Diagram, Object Diagram, Sequence Diagram, Communication Diagram, Activity Diagram, State Machine Diagram, Timing Diagram, Interaction Overview Diagram, Component Diagram, Deployment Diagram and Package Diagram. | |
| Business Process Modeling | Select and create a diagram type under Business Process Modeling, including: Business Process Diagram, Conversation Diagram, Data Flow Diagram, Event-driven Process Chain Diagram, Process Map Diagram, Organization Diagram and ArchiMate Diagram. | |
| Database Modeling | Select and create a diagram type under Database Modeling, including: Entity Relationship Diagram and ORM Diagram. | |
| Requirement Modeling | Select and create a diagram type under Requirement Modeling, including: Textual Analysis, Requirement Diagram, Basic Diagram, Open Requirements Grid, Open Glossary Grid and CRC Card Diagram. | |
| Impact Analysis | Select and create Matrix Diagram. | |
| Diagrams | Select and create other diagrams, including: EJB Diagram, Overview Diagram, User Interface and Mind Mapping Diagram. | |
| Format | Click it to open Formats dialog box. You can format font name, font style, font size, font color, line style, shape's foreground and background color and style, etc. | |
| Copier | Copy the selected diagram element's format and apply on another shape. | |
| Modeling | Click it to perform the following: Visual Diff, Animacian, Simulacian, Nicknames, Apply Design Pattern and Transit to New Diagram. Visual Diff: Launch Visual Diff for comparing diagrams. Animacian: Launch Animacian for animating the active diagram. Simulacian: Launch Simulacian for simulating the execution of business process. Nicknames: Manage and select the nickname to be applied on the working project. Apply Design Pattern: Apply the defined design pattern to the target diagram. Transit to New Diagram: Transit the current diagram to a new diagram. |
| Generate HTML Report | Open the Generate HTML dialog box to generate HTML report. | |
| Generate PDF Report | Open the Generate PDF dialog box to generate PDF report. | |
| Generate Word Report | Open the Generate Word dialog box to generate Word report. | |
| Report Writer | Open Report Writer where you can create and edit your report(s). | |
| Project Publisher | Publish project to Web pages through Project Publisher. | |
| Open Teamwork Client | Open the Teamwork Client dialog box. | |
| Commit | Commit changes to server. | |
| Update | Update changes from server. | |
| Tag | Create a tag. | |
| Branch | Create a branch. | |
| Merge | Merge changes between trunk and branches. | |
| Switch | Switch between trunk, branches and tags. | |
| Revert | Click it to undo all non-committed changes in working project. | |
| Instant Reverse |
Reverse Engineering Class Diagram from many kinds of source code, including: Instant Reverse, Java, C++ Source, .Net dll or exe files, CORBA IDL Source, Ada 9x Source, XML, XML Schema, JDBC, Hibernate, PHP 5.0 Source, Python Source, Objective-C and Java to Sequence Diagram. |
| Instant Generator |
Generate source code from the opening project, including: Instant Generator, Java, C#, VB.NET, PHP, ODL, ActionScript, IDL, C++, Delphi, Perl, XML Schema, Python, Objective-C, Objective-C 2.0, Ada95 and Ruby. |
| Reverse DDL... |
Reverse data definition language file and form ERD. | |
| Generate Code... |
Select Code > Java Round-trip > Generate Code.... |
| Reverse Code... |
Select Code > Java Round-trip > Reverse Code.... Reverse Java back into the opening project. |
| Generate Code... | Select Code > C++ Round-trip > Generate Code.... Generate C++ from class diagram for the whole project. |
| Reverse Code... | Select Code > C++ Round-trip > Reverse Code.... Reverse C++ back into the opening project. |
| Generate Code... | Select Code > State Machine Code > Generate Code... Generate state machine code from class diagram and state machine diagram. |
| Reverse Code... | Select Code > State Machine Code > Reverse Code.... Reverse state machine code back into the opening project. |
| Interoperability |
Import: VP-UML Project...: Import a VP-UML project into the opening project. Export: VP-UML Project: Export the open project into a VP-UML project file. |
Wizards... | Open the ORM Wizards. |
Database Configuration... | Open the Database Configuration dialog box to configure database connections. |
Reverse Database... | Reverse engineering from database. |
Reverse Java Classes... | Reverse engineering from Java Class. |
Reverse Hibernate... | Reverse engineering from Hibernate mapping file. |
Reverse Enterprise Object Framework... | Reverse engineering from Enterprise Object Framework. |
Synchronize to Class Diagram | Synchronize from Entity Relationship Diagram to Class Diagram. |
Synchronize to Entity Relationship Diagram | Synchronize from Class Diagram to Entity Relationship Diagram. |
Ignore Entities when Synchronizing... | Open Ignore Entities when Synchronizing dialog box to select entities to ignore during synchronizing. |
Ignore Classes when Synchronizing... | Open Ignore Class when Synchronizing dialog box to select classes to ignore during synchronizing. |
Generate Database... | Open the Database Code Generation dialog box to generate database. |
Generate Code... | Open the Database Code Generation dialog box to generate code. |
| 1. Menu bar | Table of Contents | 3. Dockable User Interface |
Technical Support
Sales Support
