Technical Support
Sales Support
You can export some shapes in a diagram as an image file by selecting the shapes you want to export then perform export. To export selected shapes to image:
| Selecting shapes to export as image |
| Set image quality |
| NOTE: | There are two options for exporting as PNG files - with and without background. With background will export diagram's background color. Without diagram will ignore the background color by exporting transparent background. |
| NOTE: | You can export VP-UML diagram to native PDF format. Since the exported PDF is of a small size, it can save a lot of space. Also, because the diagram in PDF is a vector, it is scalable. There are two different options when you export. For PDF(diagram per page), all the diagrams selected will be exported in the same PDF file. Each diagram will occupy one page. For PDF(diagram per file), each diagram selected will be exported in one new PDF file. |
| 2. Exporting multiple diagrams as images | Table of Contents | Chapter 14. Extend functionalities with Open API |
Technical Support
Sales Support
