Technical Support
Sales Support
You can import changes made externally in XML back to VP-UML, to update the project data. In this chapter, you will see how to import an XML exported before. Notice that XML import is made in response to XML export in VP-UML. Only XML exported from VP-UML can be imported.
| NOTE: | All changes made in project will be overwritten by data in XML. For example, if class Foo is renamed to Bar. By importing an XML exported before renaming class, Bar will be renamed to Foo. |
| Parameters for ImportXML |
| 1. Exporting XML | Table of Contents | Chapter 2. Export and import VP project |
Technical Support
Sales Support
