Importing BPMN 2.0
You can migrate your works done in another software to VP-UML through BPMN XML 2.0, provided that the software supports BPMN 2.0. In this chapter, you will see how to import an BPMN 2.0 file.
Importing BPMN to current project
  1. Select File > Import > BPMN 2.0... from the main menu.
  2. Specify the file path of the XML to import.
  3. Click OK.
    NOTE: All changes made in project will be overwritten by data in XML. For example, if task Foo is renamed to Bar. By importing an XML exported before renaming task, Bar will be renamed to Foo.
1. Exporting BPMN 2.0 Table of Contents Chapter 6. Importing Visio drawing
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
