Excel modification guidelines
When you are going to modify Excel file exported from VP-UML, make sure the changes you make are all valid. Making invalid changes will cause the file cannot be imported back to VP-UML. In this chapter, we will go through some of the points that you need to pay attention to when editing.
Caution
When you start to modify the Excel, pay attention to the following points to avoid having problems when importing the file back to project:
  • Do NOT modify the gray cells
  • Do NOT just delete a row for deleting a model element. Instead, change the value No to Yes under the Delete? column.
  • Do NOT modify the System Data sheet
Renaming a model element
Double click on a cell and enter a new name.
Renaming class in Excel
Deleting a model element
To delete a model element, change No to Yes under the Delete? column. Do NOT delete the row.
Deleting attribute in Excel
Adding a model element
Suppose you want to add an attribute, select the last attribute row and insert a row in Excel, right under the last one. Then, start editing it. The gray cells can leave blank.
Adding attribute in Excel
2. Importing Microsoft Excel file Table of Contents Chapter 4. Export and Import XMI
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
