Technical Support
Sales Support
Generation of ORM code and database can be done through the command line interface. To do this:
| The scripts folder inside VP Suite installation directory |
| Copy and paste GenerateORM from scripts folder to bin folder |
| Navigate to the bin folder of VP Suite in command prompt |
| Executing GenerateORM |
| Parameters for GenerateORM |
| NOTE: | If you are unable to get the execute success, try to open the project with VP-UML, run once and save. The problem is likely to occur when some files required (e.g. dialet) are unknown due to never been defined in the project file. |
| 3. Exporting and importing XML | Table of Contents | 5. Generating report through command line |
Technical Support
Sales Support
