Project publisher
To publish project through command line:
  1. Browse the scripts folder under the VP Suite installation directory.
    The scripts folder inside VP Suite installation directory
  2. Copy the script file ProjectPublisher and paste to the bin folder of VP Suite installation directory.
    Copy and paste ExportDiagramImage from scripts folder to bin folder
    Copy and paste ProjectPublisher from scripts folder to bin folder
  3. Start the command prompt.
  4. Navigate to the bin folder of VP Suite installation directory.
    Navigate to the bin folder of VP Suite in command prompt
  5. Execute the script by supplying the required parameters. For example:
    ProjectPublisher -project C:\Demo\Demo.vpp -out C:\Demo\Output
    Executing ProjectPublisher
    Below is a description of parameters:
    Parameter Description Example
    -project Project path
    C:\Demo\Demo.vpp
    -out The folder path of the files to be published
    C:\Demo\Output
    Parameters for ProjectPublisher
8. Java code synchronization Table of Contents 10. Updating teamwork project from server
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
