Printing a Diagram with Quick Print
In VP-UML, you can print a diagram with simple and easy setting by using quick print feature. The Quick Print feature allows you to print diagrams without previewing them, hence speeding up the print job.
Printing with quick print
To perform quick print:
  1. Select File > Quick Print... from main menu.
    NOTE: Alternatively, you can select Print > Quick Print... on the toolbar to launch quick print.
  2. In the Quick Print dialog box, select printout setting for the diagram.
  3. Click OK button to proceed printing.
The overview of Quick Print
No.Name Description
1 Print Range Click on one of the options to specify the print range:
  • All - Print all the diagrams within the current project.
  • Active - Print only the active diagram.
  • Diagrams - Check from the diagram tree to select the diagram(s) for printing.
2 Scaling Select No scaling to print with diagrams' original size. Numbers of pages used for each diagram are subject to the scale of diagrams. Select Fit to pages to print with specified number of pages per diagram with respect to the specified number of rows and columns.
3 Border option Select a border option of printout.
4 Page Setup... It allows you to specify the page size, the orientation as well as the margins of the pages.
5 Page numbers Select it to print diagrams with page number.
6 Use gradient color Select it to use gradient color in printout.
Details of quick print dialog box
1. Printing diagrams Table of Contents Part XV. Team collaboration
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
