Technical Support
Sales Support
In problem statement editor, you can form a diagram from candidate objects, or show it in an existing diagram by visualizing it.
| Create a model element |
| Check an option in Visualize Model Element dialog box |
As a result, the model element will be shown on the selected diagram.
| NOTE: | If you have already made a model element for the candidate object, the Create Model Element option will be hidden even after you right click on it. |
You can visualize existing candidate objects by dragging from Model Explorer and dropping on the diagram.
To visualize a candidate object or several candidate objects, select a candidate object (or a few candidate objects) from Model Explorer, drag and drop it(or them) on the target diagram. As a result, the view of the selected candidate object(s) will be shown on diagram.
| Drag from Model Explorer and drop on the diagarm |
| 3. Identifying candidate objects | Table of Contents | 5. Candidate pane view |
Technical Support
Sales Support
