Technical Support
Sales Support
Class-Responsibility Collaborator (CRC) card visualize classes in card-like presentation. Each CRC card contains information like the description of class, its attributes and responsibility. A CRC card diagram is a holder of these cards.
| Create CRC card diagram |
Click CRC Card on the diagram toolbar and then click on the diagram to create a CRC card. You can create as many as CRC card on a diagram by repeating this step.
| Create CRC card |
All properties in a CRC card must be edited inline. To edit, double click on the desired field, update its value, and click on the diagram background to confirm editing.
| Edit description |
Right-click on the Attributes heading and select Add > Attribute from the pop-up menu.
| Add attribute |
Enter the name and description. Repeat this step until all attributes are added.
| Attribute added |
Right-click on the Responsibilities heading and select Add > Responsibility from the pop-up menu. Similar to creating an attribute, enter the name and collaborator of each responsibility to show the relationship with other parties.
| Add responsibility |
| Chapter 3. CRC card diagram | Table of Contents | Chapter 4. User interface designer |
Technical Support
Sales Support
