Technical Support
Sales Support
Glossary grid is a table where you can identify specific glossary term. In addition, you can define aliases and enter documentation for the glossary term. With Visual Paradigm for UML (VP-UML), you can categorize the terms by defining and assigning label(s) to them.
Click on Requirement on toolbar and select Glossary Grid from the drop down menu.
| Open Glossary Grid |
| Glossary grid |
| The overview of glossary grid |
With VP-UML, you can categorize the terms by defining and assigning label(s) to them.
| Click Manage Label |
| Add a label |
| Enter name and select a color |
| Click the small plus button |
| NOTE: | If the Labels column doesn't show on the grid, you can click the Configure columns... button. Open Properties tab and select it under Others folder.. |
| Check a label |
| NOTE: | You can apply multiple labels to a term. Check the applicable labels in the Add Label dialog box. |
| Membership is assigned to general |
| Select With Label... |
| Check Membership |
| Terms with Membership label are listed |
You can export the glossary, along with its terms into an Excel file, and import it back to share with your teammates.
| Click Export to Excel button |
| Enter the output directory |
| 1. Identify glossary term | Table of Contents | Chapter 6. Grid diagram |
Technical Support
Sales Support
