Technical Support
Sales Support
Requirements Grid is a table with requirements listed in it. It enables you to access all requirements in a project or diagram, lookup requirements by criteria and create requirements.
Click on Requirement on toolbar and select Requirement Grid from the drop down menu.
| Open Requirement Grid |
| The requirements grid |
| The fields in requirements grid |
| Create a requirement |
| Name requirement |
| NOTE: | The requirements created in requirements grid are automatically put under the Requirements model. You may move to another model through dragging and dropping in Model Explorer. |
You can form a diagram with requirement, or show it in an existing diagram by visualizing it in requirements grid. To visualize a requirement:
| Select a requirement to visualize |
| Create visualize |
| Name a new diagram |
| Select an existing requirement diagram to visualize the requirement |
By filtering requirements, requirements that do not match the required naming convention are filtered. To filter, enter the name of requirement, or part of its name at the top right of grid. You can make use of the asterisk (*) character to represent any character(s).
| Filter requirement by name |
To find out requirements that match specific naming or documentation pattern:
| Find a requirement |
| Enter requirement name and check Name |
| Finding result |
| 2. Customizing requirement types | Table of Contents | Chapter 2. Textual analysis |
Technical Support
Sales Support
