Technical Support
Sales Support
The requirement diagram is designed specifically for the Systems Modeling Language (SysML). It is created in requirement containers and requirements to present the relationship between requirements and other model elements.
| Create new requirement diagram |
To create a Requirement, click the Requirement button on the diagram toolbar and then click on the diagram.
| Create requirement |
To decompose a Requirement, click the Containment -> Requirement resource and drag.
| Decomposing Requirement |
Move the mouse over empty space of the diagram and then release the mouse button, a Requirement together with a Containment relationship will be created.
| Requirement and Containment created |
To inline edit the property of a Requirement (e.g. ID), double-click on the property, enter new value and press Enter to confirm.
| Inline editing Requirement properties |
You can also open specification dialog box of a Requirement to edit its properties. Click Open Specification resource of the Requirement.
| Open specification of Requirement |
The Requirement Specification dialog box shows. Edit the properties and click OK button to apply the changes.
| Requirement Specification |
To create a Test Case, click the Test Case button on the diagram toolbar and then click on the diagram.
| Create test case |
Click Verify -> Requirement resource of Test Case and drag.
| Linking Requirement with Test Case |
Move the mouse over a Requirement and then release the mouse button, a Verify relationship will be created from the Test Case to the Requirement.
| Verify relationship created |
| Chapter 1. Requirement diagram | Table of Contents | 2. Customizing requirement types |
Technical Support
Sales Support
