Web Combo Box
Web Combo box is a component that combines a button and a drop-down list. User can select a value from the drop-down list to make a decision.
Creating a web combo box
  1. Select the Web Combo Box tool from the diagram toolbar.
    Selecting Web Combo Box from diagram toolbar
  2. Press to set the position of the combo box. Drag diagonally from the starting point to expand the combo box.
    Drag diagonally to expand the Combo box
  3. Release the mouse button to confirm the size of combo box.
    Combo box is created
Editing combo box values
  1. Right click on the combo box and select Open Specification... from the popup menu.
  2. In the UI tab of the UIWebComboBox Specification dialog box, click Add.
  3. Enter the value for of item and click OK to confirm.
  4. Repeat step 2 and 3 to create all the combo box items.
    Combo box items are created
  5. Click OK to confirm editing.
Combo box properties
The appearance of web combo box can be changed by editing its properties. To configure a combo box, right click on the combo box and select Open Specification... from the popup menu. The UI tab is where user can configure a combo box.
UIWebComboBox Specification's UI tab
Property Description
ID ID of the combo box in  web form.
Options The items that can be selected by users. You can optionally mark the default item's Selected to be true.
Description of web combo box properties
12. Web Text Input Table of Contents 14. Web List
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
