Web List
Web list is a component that lists out all available selection in rows, and allows the selection of values in it.
Creating a list
  1. Select the Web List tool from the diagram toolbar.
    Selecting Web List from diagram toolbar
  2. Press to set the position of the list. Drag diagonally from the starting point to expand the list.
    Drag diagonally to expand the List
  3. Release the mouse button to confirm the size of list.
    List is created
    List is created
Editing list values
  1. Right click on the list and select Open Specification... from the popup menu.
  2. In the UI tab of the UIWebList Specification dialog box, click Add.
  3. Enter the value for of item in Input dialog boxand click OK to confirm.
  4. Repeat step 2 and 3 to create all the list items.
  5. Click OK to confirm editing.
    List with values
    List with values
List properties
The appearance of web list can be changed by editing its properties. To configure a list, right click on the list and select Open Specification... from the popup menu. The UI tab is where user can configure a list.
UIWebList Specification's UI tab
Property Description
ID ID of list in form.
Options The items that can be selected by users. You can optionally mark the default item's Selected to be true.
Multiple Determine whether the list supports single or multiple item selection.
Description of web list properties
13. Web Combo Box Table of Contents 15. Web Password Input
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
