Text field
Text Field is a component that allows the editing of a single line of text. Fields in a registration form are typical examples of text fields.
Creating a text field
  1. Select the Text Field tool from the diagram toolbar.
    Selecting Text Field from diagram toolbar
  2. Press to set the position of the text field. Drag diagonally from the starting point to expand the text field.
    Drag diagonally to expand the text field
  3. Release the mouse button to confirm the size of text field.
  4. Enter the text field text and press Enter to confirm the title of text field.
    A text field is created
Text field properties
The appearance of text field can be changed by editing its properties. To configure a text field, right click on the text field and select Open Specification... from the popup menu. The UI tab is where user can configure a text field.
Property Description
Text Text refers to the text that appears in the text field.
Description of text field properties
3. Label Table of Contents 5. Scrollbar
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
