List
List is a component that list out all available selection in rows, and allow the selection of values in it.
Creating a list
  1. Select the List tool from the diagram toolbar.
    Selecting List from diagram toolbar
  2. Press to set the position of the list. Drag diagonally from the starting point to expand the list.
    Drag diagonally to expand the List
  3. Release the mouse button to confirm the size of list.
    List is created
    List is created
Editing list values
  1. Right click on the list and select Open Specification... from the popup menu.
  2. In the UI tab of the List specification dialog box, click Add.
  3. Enter the value for of item in Input dialog box and click OK to confirm.
  4. Repeat step 2 and 3 to create all the list items.
    List items are created
  5. Click OK to confirm editing.
List properties
The appearance of list can be changed by editing its properties. To configure a list, right click on the list and select Open Specification... from the popup menu. The UI tab is where user can configure a list.
Property Description
Values The items that can be selected by user.
Selected value The default selected item in the list.
Horizontal scroll bar Determines when a horizontal scrollbar will appear in a list.
Vertical scroll bar Determines when a vertical scrollbar will appear in a list.
Description of list properties
6. Combo box Table of Contents 8. Table
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
