Technical Support
Sales Support
You can set colors to nodes to represent different kinds of idea and concepts. You can also set icon(s) to a node to represent the nature of a node, such as a telephone icon for concepts related to contacting some body.
| To format nodes |
Once you have confirmed your selection, your choice will be memorized. When you want to apply the settings on other nodes, you can select the new nodes, re-open the same popup menu, and select the setting through the popup menu.
| Choosing a color for node |
Line settings control the appearance of border around node(s). You can adjust the style (e.g. dash, solid), the weight, which is the thickness of line, the color and the level of transparency.
| Nodes with brown border |
Fill settings control the background color of node(s). You can apply solid and gradient colors, as well as to control the transparency.
| Nodes with gray background |
Font settings control the font style, size, type and color of text appear on a node.
| Nodes with Times new roman text |
| To edit icons for a node |
In the Select Icons dialog box, select the icon to set and click > to assign it to the node(s). Click OK to confirm.
| To select icons for chosen node(s) |
| A node with icons |
| 1. Drawing mind mapping diagram | Table of Contents | 3. Linking nodes |
Technical Support
Sales Support
