Technical Support
Sales Support
In some cases, shapes are found oversized. For better presentation, you may need to resize them smaller. Fit size can help you to adjust shapes into the smallest size based on their content, such as the name of shape. The size of shapes can be fixed either manually or automatically.
| NOTE: | The size of shapes can be fixed automatically by right clicking on the diagram's background and checking Diagram Content> Auto Fit Shapes Size. |
To adjust a shape size, move the mouse on a shape and fit size resource centric interface will be shown. Click Fit Size resource icon at the bottom of the shape.
| Click Fit Size |
To fit several shapes' size, select those shapes, right click on a selected shape and then select Selection > Fit Size from the pop-up menu.
| Fit size for several shapes from the pop-up menu |
Each shape will be adjusted to its fit size in accordance with its content, instead of fixing all selected shapes into the exactly same size.
| Shapes are fitted size |
You can check/ uncheck the Auto Fit Shapes Size on diagram to make all the shapes on the diagram to be fitted size automatically. To do so, right click on the diagram's background, select Diagram Content > Auto Fit Shapes Size from the pop-up menu.
| Check Auto Fit Shapes Size from the pop-up menu |
All the shapes are subsequently fitted size and they will become non-sizable.
If the content of shape is changed, the shape itself will be resized automatically.
| Class shape is resized automatically after new attribute added |
You can also check Auto Fit Size for future usage.
| Check Auto fit size (diagram-based) in the Options dialog box |
| 1. Automatic Diagram Layout | Table of Contents | 3. Diagram Element Selection |
Technical Support
Sales Support
