Technical Support
Sales Support
When a number of diagram elements need selecting simultaneously, diagram element selection supports this purpose. You can either click directly with hot keys or select a range of selection with the mouse. A specific type of diagram element(s) on a diagram can be selected as well.
Multiple shapes can be selected by either selecting a range of shapes with the mouse on diagram or clicking shapes with pressing hot keys.
| Select multiple shapes with the mouse |
| Shapes are selected |
Click a shape in advance and then click other shapes with pressing Ctrl or Shift key. As a result, those shapes will be selected.
| Click shapes with pressing Ctrl or Shift key |
In some cases, the shapes are too complicated and more seriously, the whole diagram is extremely enormous that neither selecting a range of shapes with the mouse nor clicking shapes with pressing Ctrl or Shift key are the most suitable application. It is hard to drag the mouse on the large diagram, or is troublesome to click on many shapes. Using Handi-Selection is probably the best choice for you in this situation.
| Select all shapes on the right from the pop-up menu |
| All shapes on the right are selected |
When you want to select a few shapes of same types on the diagram, right click on a shape and select Selection > Select All of Same Type from the pop-up menu. As a result, other shapes of same type as the shape you selected previously will be selected.
| All shapes of same type are selected |
Shapes can be selected inversely. Right click on a shape that you don't want to be selected and select Selection > Select Inverse from the pop-up menu. As a result, all shapes will be selected except the shape you right clicked on previously.
| Selection is inversed |
| 2. Fit Shape Size | Table of Contents | 4. Copy and paste |
Technical Support
Sales Support
