Technical Support
Sales Support
VP-UML supports two types of positioning features: alignment and distribution which allow the positioning of selected shapes in accordance with the alignment/ distribution option through the toolbar or grouping resource icons. Alignment refers to the edges and the centers of selected shapes are aligned to each other while distribution refers to selected shapes are distributed in same direction based on their centers or edges.
Select a few model elements with the mouse on the diagram pane before executing alignment.
| Selected shapes |
| Shapes are aligned |
| Change the last selected shape |
| Select Align Left on resources |
Besides aligning the shapes, shapes can also be resized through the main menu, grouping resource icons or Align Shapes Dialog.
Select Edit > Align Shapes and an alignment option from the main menu.
As a result, the shapes are resized.
| Shapes are resized |
Select an option from the drop-down menu of Same Width on grouping resource icons after select a few shapes on the diagram pane.
| Resize through grouping resources |
After select a few shapes on the diagram pane, select Edit > Align Shapes > Align Shapes... from the main menu to unfold Align Shapes Dialog. You can select an option by clicking the option button directly.
| Align Shapes Dialog |
In addition, model elements can be distributed in various directions through Distribute Shapes Dialog, the main menu or grouping resource icons.
After select a few shapes on the diagram pane, select Edit > Distribute Shapes > Distribute Shapes... from the main menu to unfold Distribute Shapes Dialog. You can select an option by clicking the option button directly.
| Distribute Shapes Dialog |
Select Edit > Distribute Shapes and then select an distribution option from the main menu after select a few shapes on the diagram pane.
Select a distribution option from the drop-down menu of Distribute Horizontally on grouping resource icons after select a few shapes on the diagram pane.
| Distribute shapes on grouping resource icons |
| 10. Pinning connector ends | Table of Contents | 12. Adjusting caption's position and angle in BPD |
Technical Support
Sales Support
