Technical Support
Sales Support
Freehand shapes are multi-functional features in VP-UML. With freehand shapes, you can not only draw various kinds of shapes, but also insert an annotation. If you want to stress an important message with visual effect, you may use word art rather than using a note or a callout because you can reshape the text in word art, however, not in a note or a callout. Moreover, the shapes in freehand are flexible that you can twist them freely, but you can only resize a note or a callout.
| Freehand toolbar interface |
| Summary of freehand shape |
| NOTE: | Freehand can be switched on by clicking on diagram toolbar and select Category > Freehand from the pop-up menu. |
| Drawing with pencil |
Fine editing selector shows a second later after the freehand shape is being selected. To show it immediately, press keyboard 'N' key.
Press on a yellow selector for selecting and the selected selector will turn into orange. More fine editing selectors will appear for curve adjustment.
| Selected fine editing selector |
| Straight line created |
| Creating curve |
| A close path |
| Freehand shape created |
| Calligraphy example |
| Connecting shapes |
| A line is created |
| Clicking on straight line |
| A curve connector |
| Splitting line |
| Moving mid point |
| Line created |
| Showing fine editing selector |
| Dragging line as curve |
| Splitting line |
| Moving mid point |
| Label Line |
Click on the diagram to create a rectangle.
Click on the diagram to create a path rectangle.
Path rectangle is formed by path, which enables you to freely reshape it, while rectangle always keeps shape as a rectangle.
Click on the diagram to create a rounded rectangle.
Click on the diagram to create a rounded rectangle 2.
Rounded rectangle uses a single control point to control the deepness of corner, which ensures that the four corners remain consistent while rounded rectangle 2 uses two points to control the deepness of corner, which can produce irregular corners.
Click on the diagram to create a diamond shape.
Click on the diagram to create a parallelogram shape.
| Other trapezoid outline |
| Other isosceles trapezoid outline |
Click on the diagram to create an ellipse shape.
Click on the diagram to create a path ellipse shape.
Path ellipse is formed by path, which enables you to freely reshape it while ellipse always keeps shape as an oval.
| Other arc outline |
| Other Chord outline |
| Other pie outline |
Click on the diagram to create a hexagon shape.
| Other regular polygon outline |
Click on the diagram to create an isosceles triangle shape.
| Other Arrow Outline |
| Other two head arrow outline |
| Other Spiral outline |
| Input the text in text shape |
| Editing word art |
| 2. Callout shape | Table of Contents | Chapter 8. Resource Referencing |
Technical Support
Sales Support
