Making shape non-selectable
If you find it annoying to move some shapes carelessly or select some shapes accidentally, the function of selectable/non-selectable would be your ideal trouble-shooter. This page is going to teach you how to make shapes non-selectable or even change them back to selectable with only few clicks.
Changing the shape to non-selectable
  1. Right click on the selected shapes, uncheck Selection > Selectable from the pop-up menu.
    Selected shape to be non-selectable
  2. After the shape is non-selectable, click the shape cannot make it to be selected. Neither will the shape be selected by mouse dragging on diagram.
  3. Therefore, the non-selectable shape(s) will not be moved when other shapes are moved.
Changing the shape to selectable again
To make the shape selectable again, right click on the non-selectable shape and select Selectable from the pop-up menu.
Select Selectable
Select Selectable
Setting all shapes to selectable or non-selectable
To makes all shapes on the diagram to be selectable or non-selectable, right click on the diagram background, select Diagram Content and then select either Make All Shapes Selectable or Make All Shapes Non-Selectable from the pop-up menu.
Select Make All Shapes Selectable
6. Layer Table of Contents 8. Showing model element in multiple diagrams (Context base modeling)
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
