Technical Support
Sales Support
Visual Paradigm supports a number of ways of aligning connector caption, which apply on different modeling preferences. By default, the caption of a connector is aligned horizontal only, but you also can customize it to Follow Diagram, Horizontal Only, Horizontal or Vertical Only, Follow Connector Angle, and Follow Connector Angle and Keep Text Up Right. You can either customize it one by one or change all connectors in the diagram which defined Follow Diagram.
| Sample class diagram |
To customize the caption orientation option of a specify connector, select the connector, right click and select Style and Formatting > Connector Style, and then select one out of four options under Caption Orientation.
| Change caption orientation to Follow Connector Angle |
| Follow Connector Angle sample |
| The description of 4 caption orientation options |
In addition to the 4 options mentioned above, Follow Diagram is another choice for altering the connector. The main feature of Follow Diagram is, all connectors in the diagrams can be changed simultaneously instead of setting one by one.
Right Click on the diagram background, select Connectors and select one out of four options under Caption Orientation from the popup menu.
| Change caption orientation by diagram popup menu |
Workspace wide setting affects the new connectors being created in projects created or will be created under the current workspace, including the opening project. To set, select Tools > Project Options from the main menu.
In the Options dialog box, open the Diagramming page, switch to the Connector tab and select the desired way of aligning caption under the Caption Orientation drop down menu. At last, click OK to confirm the changes.
| Selecting Horizontal only in Options dialog box |
| 4. Setting line jumps options | Table of Contents | 6. Format copier |
Technical Support
Sales Support
