Adjusting user interface font
VP-UML runs with a screen design that is friendly enough for most users, so that you can customize it to make it suit your preference. One of the possible customization is to adjust the font settings for text appears on user interface, like the button caption for tools in toolbar, diagram editor tab's title, menus' captions, etc. The settings will be stored in workspace. Hence, you can keep the settings every time you run VP-UML.
To adjust font settings:
  1. Select Tools > Application Options from the main menu.
  2. Select General from the list on the left hand side.
  3. Open the Appearance page.
  4. Check Change application font in the Font section. Adjust the font type and size.
    Adjusting font settings
  5. Click OK.
  6. Restart the application to let the settings take effect.
    Updated user interface
1. Hiding user interface components Table of Contents Part X. Code and DB engineering
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
