Drawing stored procedures
Stored Procedure is a set of Structured Query Language (SQL) statements with an assigned procedure name that’s stored in the database in compiled form and is part of a relational database.
Creating stored procedures shape
Click Stored Procedures from diagram toolbar and drag it on the diagram pane.
Create stored procedure shape
Specify the name for the newly created stored procedures and press Enter.
Rename procedure shape
NOTE: Procedure shape is a virtual container to group a set of stored procedures. It is not a stored procedure.
Creating procedure
Right click on the stored procedures and select New Procedure from the pop-up menu, or press Alt+Shift+P.
After the new procedure is created, right click on it and select Open Specification... from the pop-up menu. In Procedure Specification dialog box, specify the create statement and create parameters if necessary.
Specify create statement in Procedure Specification dialog box
Moving or duplicating a procedure to another procedure container
  1. Select the procedure to move or duplicate.
    Selecting procedures to move or duplicate
    Select procedures to move or duplicate
  2. Drag over the target procedure container.
    Dragging procedure towards the target procedures container
    Drag procedure towards the target procedures container
  3. If you want to duplicate the procedures, press on the Ctrl key and release the mouse button. If you want to move them from source to target procedure container, just release the mouse button.
    Procedures are moved
Creating stored procedure resultSet
Click Stored Procedure ResultSet from diagram toolbar and drag it on the diagram pane.
Create stored procedure resultset
After specify the name for the newly created resultset, press Enter.
Rename stored procedure resultset
The way of creating resultset column is the same as creating entity column.
Right click on the procedure that created above, select Open Specification... from the pop-up menu. In Procedure Specification dialog box, specify stored procedure return resultset.
Specify stored procedure return resultset
2. Drawing sequence Table of Contents 4. Drawing triggers
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
