Instant Reverse Options
Option Name
Description
 .NET
  • Not specified - (default) Do not specify whether Instant Reverse of .NET is enabled or not.
  • Enabled - Enable Instant Reverse for .NET
  • Disabled - Disable Instant Reverse for .NET
C++
  • Not specified - (default) Do not specify whether Instant Reverse of C++ is enabled or not.
  • Enabled - Enable Instant Reverse for C++
  • Disabled - Disable Instant Reverse for C++
Text File Encoding
  • System default - (default) The default system encoding will be selected as encoding for source files that will be reversed
  • Other - Specify an encoding for the source files that will be reversed
Show Instant Reverse Form Diagram dialog after Instant Reverse (default true) Show the Instant Reverse Form Diagram dialog box after Instant Reverse so that you can form diagram after reversing code into VP-UML.
Instant Reverse Options details
Chapter 4. Instant Reverse Table of Contents Chapter 5. ORM
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
