Keys Options
Customizable program shortcuts
Commands can be invoked by pressing certain keys in the keyboard, as shortcuts. For example, holding down the Ctrl modifier key with the 'S' key invokes the save command. Now, key bindings, which is the assignment of keys to commands, can be customized. This permits you to use the familiar keystroke for invoking commands in VP-UML.
To assign/re-assign a key:
  1. Double-click on the binding cell of the desired action.
  2. Click on the Binding field at the bottom of dialog box.
  3. Press the key for invoking the command selected. The binding field will be updated accordingly.
  4. Press OK button to confirm the updates. You will be prompted to restart the application in order to make the changes take effect. By restarting, you can invoke commands using the key defined.
Chapter 11. Keys Table of Contents Chapter 12. Import/Export
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
