Interaction Options
Option Name
Description
Mark target lifeline stopped when attached by destroy message The effect when attaching a Destroy Message to a Lifeline, whether the Lifeline will be marked stopped or not
  • Yes - Lifeline will mark as stopped
  • No - Lifeline will not mark as stopped
  • Prompt - (default) Ask if you want to mark the Lifeline as stopped
Show sequence number in Communication Diagram (default true) Show numbering on Sequence Message in Communication Diagram.
Show sequence number in Sequence Diagram (default true) Show numbering on Sequence Message in Sequence Diagram.
Show messages operation signature in Sequence Diagram and Communication Diagram (diagram-based) (default false) Show Sequence Messages' operation signatures in Sequence Diagram and Communication Diagram.
Show stereotype of message in Sequence Diagram and Communication Diagram (diagram-based) (default true) Show Sequence Messages' stereotypes in Sequence Diagram and Communication Diagram.
Show activations in Sequence Diagram (diagram-based) (default true) Show Activations in Sequence Diagram. If unchecked, sequence message will be attached to Lifeline instead of Activations.
Display as Robustness Analysis icon in Sequence Diagram (default true) Display Lifeline as robustness analysis icon for Lifelines stereotyped as boundary/control/entity.
Show associated diagram name of Interaction (default false)
Interaction Options details
9. ERD & ORM Table of Contents 11. Use Case Diagram
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
