Technical Support
Sales Support
UML is theoretically a modeling language independent to particular programming language(s). Yet, it is possible to transform between UML models to a software applications or systems. While the pre-defined data-type set works well in the UML world, there is enormous need to ensure the design can be applied to programming source code. Problems comes from the fact that programming languages, by nature, are unlikely to share the same set of data-types suggested by UML. A typical example is about the use of boolean. ‘boolean’, ‘bool’ and ‘Boolean’ are adopted by UML and Java, C# and VB.NET respectively. But they are all referring to the same thing – boolean.
Visual Paradigm lets you choose a programming language that your UML project should be based on. When modeling, you can easily select a data-type that is allowed for the chosen language, without typing it. Besides, new languages and data types can be added, which increase the flexibility of working under different domains.
By default, there are six types of predefined (programming) languages. Each of them consists of a set of supported data types. Besides working with those default languages and types, you can add your own languages and add data types. To do so:
| Chapter 6. Data Type | Table of Contents | Chapter 7. Code Synchronization |
Technical Support
Sales Support
