Code Options
Option Name
Description
Default attribute type (default int) Type that will be assigned to Attribute upon code generation when type is unspecified.
Default operation return type (default void) Return Type that will be assigned to operation upon code generation when return type is unspecified.
Default parameter type (default int) Type that will be assigned to Parameter upon code generation when type is unspecified.
Text File Encoding
  • System default - (default) The default system encoding will be selected as encoding for source files
  • Other - Specify an encoding for source files
Code Options details
Chapter 8. C++ Code Synchronization Table of Contents 2. Brace and Indentation
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
